Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
TLS SSL/HTTLS can't be work
Tconnell
Hi Intel,
I follow #631070 TLS Doc rev1.2 - 1.3.1
setup SSL still can not be work
still show unsafe
BTW:
doc setup step seems only windows chrome, I also try ubuntu chrome
and restart browser ,  still can not be work
JesusE_Intel
Hi Tconnell,
From the screenshots it looks like you are following the correct steps. However, it looks like you are trying to access TLS using localhost. Instead, try accessing it using the IP address: https://<system ip>
Jesus
JesusE_Intel
Hi Tconnell
Did you clear your cache and restarted your browser after you installed the ca_certificate.pem under Trusted Root Certificate Authorities? On my side, TLS also showed as unsafe until I cleared my cache and restarted my browser.
Jesus
Tconnell
Yes, ca_certificate.pem and Trusted Root Certificate Authorities
and cleared cache and restarted my browser.
Can you help me check my step is correct?
attachment is my step(Ubuntu/Windows Chrome)
JesusE_Intel
Hi Tconnell,
Jesus
Tconnell
Hi Jesus,
Thanks you so much,
It can be work now.
External IP - work       (https://10.1.x.x
Internal IP - not work(https://127.0.0.1)
localhost - not work  (https://localhost)
Tconnell
Hi Intel,
Sorry, one more question.
Does this setting can not work on TLS docker version?last reply is naive version.
I follow same step, delete old cert, import docker ssl cert, clear cache, restart web browser
and connect external ip https can not work
JesusE_Intel
Hi Tconnell,
It should work with TLS Docker as well. In fact, when I was testing this from my end I used setup_TLS_docker.sh when setting it up.
Jesus
JesusE_Intel
