Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
415 Discussions
eci - run sudo apt install libudev-dev not depends :libudev-dev not install
junjuns
install libudev-dev depends : error libudev-dev :Depends :libudev1 (=249.11-0ubuntu3.12) but 249.11-0ubuntu3.12-ecir5.......,
Iffa_Intel
to clarify, could you share:
  1. your OS and version (eg: Ubuntu 22.04)
  2. your hardware info (eg: CPU GPU etc)
  3. your reference eg url of the ECI guide (to clarify whether you are referring to the latest guide)
Cordially,
Iffa
junjuns
apt dependency problem, is a different package from eci, installed libudev-dev 249.11-0ubuntu3.12-ecir5........ deb, you have found the eci compilation directory, put the dpkg-i package name.deb on the target machine, and install it.
Iffa_Intel
could you elaborate further regarding your issue?
Do you mean that you are unable to install libudev-dev using the command sudo apt install libudev-dev after installing the ECI package?
Please help to provide informations that I asked previously too.
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread
Cordially,
Iffa
