install libudev-dev depends : error libudev-dev :Depends :libudev1 (=249.11-0ubuntu3.12) but 249.11-0ubuntu3.12-ecir5.......,
to clarify, could you share:
- your OS and version (eg: Ubuntu 22.04)
- your hardware info (eg: CPU GPU etc)
- your reference eg url of the ECI guide (to clarify whether you are referring to the latest guide)
Cordially,
Iffa
apt dependency problem, is a different package from eci, installed libudev-dev 249.11-0ubuntu3.12-ecir5........ deb, you have found the eci compilation directory, put the dpkg-i package name.deb on the target machine, and install it.
could you elaborate further regarding your issue?
Do you mean that you are unable to install libudev-dev using the command sudo apt install libudev-dev after installing the ECI package?
Please help to provide informations that I asked previously too.
Cordially,
Iffa
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread
Cordially,
Iffa
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
