- « Previous
- 1
- 2
- Next »
Hi, yes i am able to install it now and after installation video streaming can also be seen, but unable to access webUI, there is lot mentioned in userguide which I think, I am unable to follw properly.
That's great news! I'm glad things work out for you.
Is your VM networking running in Network Address Translation mode? Perhaps its added complexities caused the issue. I use bridging mode.
About the webUI you were not able to access, is it the ETCD web UI? Please make sure the ia_etcd_ui container is running and access it on port 7070, for example, http://localhost:7070/etcdkeeper/.
Please feel free to create a new inquiry here if you need additional help. Take care.
Yes, I was using NAT which was causing issue, now I am using Bridging mode.
Thank you for confirming my hypothesis. If others encounter a similar issue with their VM-based environment in the future, we will know what to suspect!
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- 1
- 2
- Next »
