We are using Embree to render Catmull-Clark subdiv mesh. The result is broken as there are two vertices with valence of 50.
We figured out the maximum valence is 32 as set in file of kernels/subdiv/catmullclark_coefficients.h
static const size_t MAX_RING_FACE_VALENCE = 32; //!< maximum number of faces per ring static const size_t MAX_RING_EDGE_VALENCE = 2*32; //!< maximum number of edges per ring
Is it possible to change the value such as
static const size_t MAX_RING_FACE_VALENCE = 64; //!< maximum number of faces per ring static const size_t MAX_RING_EDGE_VALENCE = 2*64; //!< maximum number of edges per ring
We tried to rebuild one but sometimes crashes inside rtcCommitScene
Are there anything else we need to take care or it is just impossible?
We are working on version v3.3.0
Thanks a lot!
Xin
This will be fixed in Embree 3.5.1.
			Topic Options
