Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
TBB version used in Windows binary distribution
Haas__Nicholas
Greetings,
Which version of Intel TBB is the latest version of Embree 2 (v2.17.5) built against in the Windows binary provided by Intel?  We are using TBB for other parts of a program and need to find the TBB header files that align with the version of TBB that ships with said distribution.  We would like to avoid re-compiling from scratch.
The release announcements for Embree 2 indicate they were last updated to TBB 2017 in Embree 2.12, that was a while ago, and when I right click on the tbb.dll that is bundled with v2.17.5 and examine its properties, I see 2017.0 and 2016.722 mentioned in Product version.
I suspect simply overwriting the TBB dll with the latest TBB releases DLLs would be a bad idea since Embree 2 was likely compiled against a different (major) version of TBB.
SvenW_Intel
Embree v2.17.5 from the ZIP file (https://github.com/embree/embree/releases/download/v2.17.5/embree-2.17.5.x64.windows.zip) is linked against TBB 2017.0 (https://github.com/intel/tbb/releases/tag/2017). You can figure this out by running ./verify when you downloaded Embree.
