Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
Custom version of TBB with CMAKE
Tony_M_2
I have a custom version of TBB where I changed a few bugs that are waiting to be approved, but make the data structures more thread safe.
My issue is in my cmake file
# Build Thread Building Blocks (main shared libraries only)
set(TBB_ROOT "tbb" CACHE FILEPATH "description")
set(TBB_BUILD_SHARED          OFF  CACHE BOOL " " FORCE)
set(TBB_BUILD_STATIC          ON  CACHE BOOL " " FORCE)
set(TBB_BUILD_TBBMALLOC       OFF CACHE BOOL " " FORCE)
set(TBB_BUILD_TBBMALLOC_PROXY OFF CACHE BOOL " " FORCE)
add_subdirectory(tbb)
set_property(TARGET tbb_static tbb_def_files PROPERTY FOLDER "dependencies")
# EMBREE setup
SET(ENABLE_TUTORIALS OFF CACHE BOOL "Tutorials")
SET(ENABLE_INSTALLER OFF CACHE BOOL "Installer")
SET(ENABLE_ISPC_SUPPORT OFF CACHE BOOL "ENABLE_ISPC_SUPPORT")
#SET(LIBRARY_OUTPUT_PATH ${PROJECT_BINARY_DIR}/lib)
add_subdirectory (embree)
CMake Error at C:/Program Files (x86)/CMake/share/cmake-3.3/Modules/FindPackageHandleStandardArgs.cmake:148 (message):
Could NOT find TBB (missing: TBB_LIBRARY TBB_LIBRARY_MALLOC)
Call Stack (most recent call first):
C:/Program Files (x86)/CMake/share/cmake-3.3/Modules/FindPackageHandleStandardArgs.cmake:388 (_FPHSA_FAILURE_MESSAGE)
external_dependencies/embree/common/cmake/FindTBB.cmake:86 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
external_dependencies/embree/CMakeLists.txt:131 (FIND_PACKAGE)
So is there a way I can include a custom version of TBB with my project without Embree's  CMAKE   foricing  a  notfound  error
SvenW_Intel
If your TBB library and headers are in non-default locations, just set TBB_ROOT to "". Then you can set the other TBB variables by hand:
SET(EMBREE_TBB_ROOT "")
SET(TBB_INCLUDE_DIR "tbb/include")
SET(TBB_LIBRARY "tbb/libtbb.so")
SET(TBB_LIBRARY_MALLOC "tbb/libtbb_malloc.so")
Tony_M_2
My issue is when I include it in a project, I am not going to ship it with the .so (or lib) files pre-built.
I want to build them first in the make / visual studio project file.
So specifically lines :  48,49    70 71   of the FindTBB.cmake file are the ones screwing me up
    SET(TBB_LIBRARY TBB_LIBRARY-NOTFOUND)
    SET(TBB_LIBRARY_MALLOC TBB_LIBRARY_MALLOC-NOTFOUND)
I saw this in another post:
https://github.com/embree/embree/issues/48
Where they sugguested deleting it made things work.
Doing that allowed me to build the entire project, TBB, embree, etc from scratch and my project fine those custom dependencies.
I understand that might cause issues, but perhaps providing a flag that lets a user do that where those lines are deleted in the FindTBB will help satisfy some users...so we can purposely turn on that flag, and those 4 lines don't yell
Then something like this will work
set(TBB_ROOT "${CMAKE_CURRENT_SOURCE_DIR}/tbb" CACHE FILEPATH "tbb root")
set(TBB_INCLUDE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/tbb/include" CACHE FILEPATH "tbb include")
So that everything builds on the fly.
I would love if you could just delete those 4 lines, but understand you cann't
perhaps providing a flag here will help bring a compromise
BenthinC_Intel
Hi Tony,
we will look into this for the next release.
Wu__YunHsiao
Hi there,
just wondering if there's any update on this, same situation here after all this time.
Haas__Nicholas
@wu I was encountering issues with simply setting 'EMBREE_TBB_ROOT` as well with Embree v2.17.7 and (compiled from source) TBB 2017.  Here is how I cleared it.  It would appear that the CMake find is expecting a certain directory structure.
Sampling of directory structure of my custom tbb 2017 install:
file /tmp/tbb_release/lib/libtbb.so /tmp/tbb_release/lib/libtbbmalloc.so /tmp/tbb_release/include/tbb/tbb.h
This then works:
cmake -DEMBREE_ISPC_SUPPORT=OFF -DEMBREE_TBB_ROOT=/tmp/tbb_release ..
Parmesano
Nice !! Thanks
