Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
ssef constructor question
P_V__Hariprasad
Sory, don't undestand much SSE, but why this constructor was commented:
__forceinline ssef           ( float  a ) : m128(_mm_set1_ps(a)) {}
and now this one is used:
__forceinline ssef           ( const float&  a ) : m128(_mm_castsi128_ps(_mm_shuffle_epi32(_mm_castps_si128(_mm_load_ss(&a)), _MM_SHUFFLE(0, 0, 0, 0)))) {}
The other constructors are still using _mm_set_ps().
SvenW_Intel
I think the commented out version should be the better choice, as it does not enforce reading the float from memory.
P_V__Hariprasad
Ok, thanks for clearing that out. The actual problem I had is that I must be able to pass also doubles there. And since I'm a SSE noob, I really don't like such exotic code there :). Will restore the old constructor with clear conscious now :).
