Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
sunlight and glass material
Daniele_G_
Hello everybody,
I'm trying the last embree examples with sphere_glass.xml test scene. I just replaced the HDRILight with DISTANTLIGHT as follow:
<DistantLight>
<AffineSpace>
    0   0   -0.000000   0
    0   0   -0.777146   0
    0   0   -0.629320   0
</AffineSpace>
<L>350.000000 350.000000 350.000000</L>
<halfAngle>2.000000</halfAngle>
</DistantLight>
I this case, and every times I render a scene with glass objects and sunlight, lots of white dots appears and the scene will never be clean, as you can see in the attached. Does somebody know why and how to solve?
SvenW_Intel
The Embree path tracer is quite limited and has these issues with some light transport paths. You can workaround the problem by increasing the opening angle of the distant light (larger halfAngle parameter).
Daniele_G_
Dear Mr. Woop,
Thank you for your answer. I would like to tell you that I noticed that this problem was not there in the version 1.x, in which you could use the distant light with every type of angle. Just from the version 2.x and next I noticed this trouble.
