Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
230 Discussions
EM2130 default configuration
PCrou1
I am considering using an ENPIRION EM2130L02QI.
The PMBUS enables setting the TON_DELAY parameter but we are not going to use this feature.
What is the default value for the parameter (I wasn't able to find the value in the datasheet)
Mostafa_Intel_AE
Hello Pascale,
EM2130L02 has a Ton_Delay default value is 250us once Ctrl signal is asserted high with assuming the VCC voltage is already settled up before the CTRL signal by 5ms.
Mostafa
PCrou1
Hello Mostafa, Thank you for your answer and this is consistent with our design. Best regards, Pascale Bien cordialement, Pascale Crouzillat
