Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
230 Discussions
I am using the EM2120H01QI and want to set the output voltage to +3.6V, I do not see how to do this in the datasheet can you provide the values for RVSET, R1DIV and R2DIV.
JMorr38
Mostafa_Intel_AE
Hello Jim,
To generate 3.6Vout from EM2120H, you need to adjust the following component
RVSET = 6.81K
R1DIV= 2K
R2Div= 665Ohm
Please note that, if you are using the PMBUS to read back the Vout, you will need to scale the Vout reading value by 2, but the actual voltage that the board generates will be 3.6V.
Mostafa
