Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
230 Discussions
Power analyzer Cyclone V inconsistent results
DBECK14
summary_current.JPGsummary_power.JPGI am using the power analyzer tool in Quartus 18.1 for a Cyclone V device with HPS. The power analyzer summary says that the single core HPS dynamic power is 884 mW.
When I look at the "Current Drawn form Voltage Supplies"
window, it shows VCC_HPS drawing 6.48 mA, or 7.1 mW at 1.1Volts.
I don't see any other current draws that will add up to the 884mW number.
SreekumarR_G_Intel
Total current 6.4 mA is static current ; and Dynamic power is 884 mW ; please dont mix both ; since both are two different things;
About the Dynamic power calculation ; In general product of switching frequency ,Capacitance load * square of Voltage *Number of Elements or bits ; I am not sure how tool is calculating the HPS dynamic power since HPS is too complicated.
I would use the EPE instead of power Analyzer for the HPS section.
Thank you,
Sree
DBECK14
Thank you for the advice, however, I downloaded the Cyclone IV, Cyclone V EPE V16.1, Build 10.28 and it does not work properly. When the Cyclone V family is chosen, the device list remains all Cyclone IV parts, it does not change to Cyclone V parts. The website said this is the final build.
SreekumarR_G_Intel
ah....not sure why EPE sheet not working for you; I just downloaded 16.1 version and checked ..It is working fine for me .
Can you check you enable the macro options in excel sheet ?
Thank you ,
Sree
