- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
We have been using the Agilex™ 7 R-Tile Compute Express Link* (CXL*) FPGA . We are not seeing any electrical activity on the link adn no traininig is happening . Our assumption is that the bitstream of the FPGA is already present and we should see the link trained on our hosts but that is not happening at the moment . Can you help us find out why there is no activity on the link ?
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Before addressing your question, I would like to clarify a few things:
- Are you using the Rtile FPGA DEV KIT and the CXL example design? If so, could you specify the model and Quartus version you are using?
- Since CXL is based on PCIe 5.0, have we successfully run the PCIe 5.0 example design on the same card and correctly identified the device?
- Additionally, have you checked whether your system supports the CXL protocol?
WZ
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
1. Yes I am using the FPGA dev kit to deploy the CXL design that is already implemented . My assumption was that the hardware will be plug and play unless I need to change something in the design on the FPGA. I am using Quartus 23.1 . I have been following this manual "Agilex™ 7 FPGA I-Series Development Kit User Guide" . I see the license listed on Intel® FPGA Self-Service Licensing Center. The problem right now is that I do not have a computer associated with this fixed license.
When I try to add a new host , I see a window and I do not understand the fields here . Is there a document that I could follow to fill these in ?
2. Once I have access to this I would like to enable the inherent cxl design and try using it . I hope the path I am following to get this thing work is the right one.
3. Yes, the system I am using supports cxl and other cxl 2.0 devices work on it .
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi there,
Although I'm not very familiar with the system you mentioned, I believe the computer name and ID listed in your picture should correspond to the "Device Name" and "Device ID" found in "System -> About". If my answer is incorrect, you can submit a case related to lic (apologies, I am unable to help you copy the case to them in this system). They have more experience in this area than I do.
WZ
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
