Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1155 Discussions
Couldn't open "transcript": permission denied and Cannot open macro file alarm in Modelsim-intel
rMa1
I am the beginner of ModelSim-INTEL FPGA STARTER EDITION, when I open the design example "Quartus_PRO_PLL_RAM",  Couldn't open "transcript": permission denied.
and Cannot open macro file: example.do.
I am using quartus prime pro edition 20.2.
rMa1
My project location is "C:\Users\mar1\Desktop\Quartus_PRO_PLL_RAM" in my computor.
RichardTanSY_Intel
Couldn't open "transcript": permission denied - I usually ignored this as I always read the transcript in notepad++.
The reason why you cannot open macro file: example.do is most probably your Modelsim directory path is currently not located at /Users/mar1/Desktop/Quartus_PRO_PLL_RAM/mentor - where the example.do file located.
1. Go to File > Change Directory > Browse to the directory path where the example.do file located.
2. type pwd - to confirm the directory path is correct
Modelsim > pwd
3. then do example.do
Modelsim > do example.do
With that, the Modelsim should bring up the simulation.
rMa1
I had open and successful complied the design file.
In my design, when I load the micro file tb/wave.do, there is empty in the object window, and then a alarm  "load canceled" jump out.  How should I do?
RichardTanSY_Intel
May I know what steps have you performed to cause this issue? Could you help to describe further on this? Is this based on the previous design files that you attached?
SY (Richard)
RichardTanSY_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
 Shyan Yew (Richard)
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
