Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
DSP Builder License Activation
Jerry_Yang1
 I want to activate my DSP Builder License using the Hardware disk serial number, but in the activation process, there is no “Hardware disk serial number” option, so I am confused.
CAN I activate my license on Hardware disk, or I must activate the license using the NIC ID method?
ShengN_Intel
Yes, only NIC ID or Guard ID.
Sheng
Jerry_Yang1
Thank you for you explain.
As far as I know, once the License is bound, it can't be replaced. Right now, our existing computers are too old to need updating, so the NIC method shouldn't be suitable for us. Is there any good suggestion for this License binding?
If we use the Guard ID method,  can I use the DSP Builder in the new PC, and is the "USB dongle " for sale?
Thank you!
ShengN_Intel
Yup, if use guard id you can reuse the DSP Builder license in New PC. You may rehost it check link https://www.intel.com/content/www/us/en/docs/programmable/683472/23-1/rehosting-all-licenses-from-current.html
For "USB dongle " , you may need to consult the distributor site https://www.intel.com/content/www/us/en/partner/showcase/partner-directory/distributor.html#sort=relevancy
Sheng
ShengN_Intel
May I know do you have any further concern?
Sheng
Jerry_Yang1
I don't have any questions right now, and I will try rehost and use the dongle first.
