Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
Error (213009): File name "output_files/afu_fit.green_region.pmsf" does not exist or can't be read
SMelz
since December 2019 (after an ubuntu update)
we have this error:
aoc device/hello_world.cl -o bin/hello_world.aocx
aoc: Running OpenCL parser....
aoc: Optimizing and doing static analysis of code...
Compiling for FPGA. This process may take a long time, please be patient.
Error: Quartus Prime Convert_programming_file was unsuccessful. 1 error, 0 warnings
Error (23031): Evaluation of Tcl script a10_partial_reconfig/flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 7 errors, 3326 warnings
Error: Compiler Error, not able to generate hardware
Is there any solution?
Simon
Ubuntu 16.04.6 LTS (Xenial Xerus)
Intel Acceleration Stack for Intel Xeon CPU with FPGAs Version 1.2
with Intel® Quartus® Prime Pro Edition 17.1.1
SMelz
where can i get a new "Free" License for Quartus® Prime Pro Edition 17.1.1:
Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
   Warning (115005): Unlicensed IP: "PCIe SRIOV with 4-PFs and 2K-VFs(6AF7 00FB)"
   Warning (115005): Unlicensed IP: "Low Latency 10Gbps Ethernet MAC(6AF7 0119)"
   Warning (115005): Unlicensed IP: "Low Latency 40Gbps Ethernet MAC and PHY(6AF7 011B)"
   Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition_2cedade0/17.1.1/final/1/netlist.model"
   Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition_2cedade0/17.1.1/final/1/names.model"
   Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition/17.1.1/final/1/netlist.model"
   Warning (115004): Unlicensed encrypted design file: "/opt/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/hello_world/bin/hello_world/build/qdb/_compiler/afu_fit/root_partition/17.1.1/final/1/names.model"
Simon
SMelz
the Kernel is 4.15.0-45-generic
opt/inteldevstack/a10_gx_pac_ias_1_2_pv/bin# ./run.sh
ERROR: JSON metadata definition not found.
I think it's a License Problem...
Simon
MEIYAN_L_Intel
Regarding the content you asked, it is a known issue that the license of three IPs attached to the Acceleration Stack has expired at the end of 2019 attached to the Warning.
As a result of the license expiring, GBS cannot be generated successfully.
Could you try to contact the local sale?
sstoe3
As of 01/01/2020 the following have become Unlicensed with the Acceleration Stack Version 1.2.
; Assembler Encrypted IP Cores Summary ;
; Vendor ; IP Core Name ; License Type ;
; Altera ; PCIe SRIOV with 4-PFs and 2K-VFs (6AF7 00FB) ; Unlicensed ;
; Altera ; Low Latency 10Gbps Ethernet MAC (6AF7 0119) ; Unlicensed ;
; Altera ; Low Latency 40Gbps Ethernet MAC and PHY (6AF7 011B) ; Unlicensed ;
; Altera ; Signal Tap (6AF7 BCE1) ; Licensed ;
; Altera ; Signal Tap (6AF7 BCEC) ; Licensed ;
4315 Info (16677): Loading final database
4316 Warning (292015): License for core 6AF7_0119, version 0000.00 is expired.
4317 Warning (292015): License for core 6AF7_00FB, version 0000.00 is expired.
4318 Warning (292015): License for core 6AF7_011B, version 0000.00 is expired.
According to the documentation "You do not need to purchase the license separately for these IPs."
Please advise ASAP to what is required to get a new license?
MEIYAN_L_Intel
Yes, the licenses bundled in Acceleration Stack are expired from Jan 2020.
Based on my understanding, the license patch had released in RDC (resource and design center) and customers need to sign CNDA to access this page.
If you need to use the it urgently, you have to find local FAE to request temporary (30 days) evaluation licenses.
sstoe3
License Patch for Intel Acceleration Stack v1.2 for Intel FPGA PAC with Intel Arria 10 GX:
Link
Download
MEIYAN_L_Intel
This package includes README.txt and one Quartus patch.
Please note that the IP license expiry date is extend to 12/2022 as stated in README.txt.
YuPengHou
Do you resolve it?
