Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1345 Discussions
Error compiling hello_world.cl with aoc
gbarc2
I recently installed the Intel OpenCL SDK toolchain for FPGA on a Linux system by following the guide provided here https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf.
Since our board is an Intel PAC with Arria 10 GX, I also installed the Custom Platform for the board.
Running
aoc -version
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 17.1.1 Build 273
Copyright (C) 2017 Intel Corporation
quartus_map --version
Quartus Prime Analysis & Synthesis
Version 17.1.1 Build 273 12/19/2017 Patches 1.02dcp,1.36,1.38 SJ Pro Edition
Copyright (C) 2017 Intel Corporation. All rights reserved.
therefore aoc and Quartus are installed. I also ran "aocl diagnose" and it correctly passed the diagnostic for the board.
Then compiling the hello_world.cl kernel in emulation mode
aoc -v -march=emulator -board=pac_a10 hello_world.cl
worked without any problem (also at runtime the binary worked).
However, running
aoc -v -board=pac_a10  hello_world.cl
c: Environment checks are completed successfully.
aoc: Cached files in /var/tmp/aocl/ may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected target board pac_a10
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Optimizing and doing static analysis of code...
aoc: Linking with IP library ...
Checking if memory usage is larger than 100%
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error: Compiler Error, not able to generate hardware
Therefore, I looked at hello_world.log (see attached) and there is no indication of why the compilation failed.
Then, I looked at quartus_sh_compile.log and the only line reported is
ERROR: packager tool failed to run. Check installation. Aborting compilation!
Could you please help us understand where the issue may be?
Many thanks.
KhaiChein_Y_Intel
Hi Simon,
This thread is closed since May 2019. Could you open a new forum thread?
