Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
Errors Quartus while device and Questa plugin
shriram_INTL
Hi all,
Link the simulator's path to the EDA path settings. Since an error message appeared, it is incorrect, I 'm using EDA Guide as a reference
  • Stratix 10: Device software has been downloaded; how should it be installed?
    Stratix 10 I am using link as an reference to install the device
    - Alternate approach – via installer , I am still having issues
    • Testbench: Execute testbench. EDA Guide .This is final step before I get above addressed
    I am using Quartus Pro standard version 21.1
    Thank a lot
    Sriram
Ash_R_Intel
For the simulator, you need to provide the path of the directory containing the vsim.exe (for Windows).
To install the device, please specify the directory of the containing .qdz file. The file name is not required, as in your screen shot.
shriram_INTL
I tried "C:\intelFPGA\21.1\questa_fse\win64\vsim.exe" but this doesn't work .
File sqrt_int16_nativelink_simulation.rpt is empty "0KB"
Also , I tried without *.qdz , Just directory i.e. without filename. still i don't have luck.
Sriram
shriram_INTL
If you require further clarification or have additional suggestions, please contact me at malladi.sastry@intel.com. or you can share your contact info.
Thank you
Ash_R_Intel
As discussed over call, the EDA path should be updated to the path containing vsim.exe. Example, 'C:/intelFPGA_pro/21.2/questa_fe/win64'
For the device installation, Stratix 10 device is supported by Quartus Pro Edition only. So, install the Quartus Pro Edition software first and then try installing the device .qdz file.
For more information of device wise Quartus support, refer to https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/devices-support.html
Download the Quartus installation files from following link:
https://www.intel.com/content/www/us/en/software-kit/734898/intel-quartus-prime-pro-edition-design-software-version-22-2-for-windows.html?
Closing the ticket for now. It will still be open for the community members to comment.
shriram_INTL
Thanks a lot for your kind help. I can work now.
best regards,
Shriram
