Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
Hi, I'm having some issues with regards to running the examples for the HLS compiler 18.1. I've installed all the prerequisites are expected and I'm just running the simple demo for counter and the error I'm getting is shown below:
MSura2
COMMAND:
make test-x86-64
ERROR:
i++ counter.cpp  -march=x86-64 -o test-x86-64
error: unable to open output file 'counter4716.o': 'Error opening output file 'counter4716.o''
1 error generated.
HLS x86-64 compile FAILED.
Makefile:40: recipe for target 'test-x86-64' failed
make: *** [test-x86-64] Error 1
ISSUE:
I have no idea how to resolve it, or what is causing the error. The object file doesn't exist and I'm not sure why it's not being generated by the makefile, any suggestions on how to fix this error?
AnilErinch_A_Intel
Hi ,
Can you include the path to your include directory also like shown below, and also include additional compiler options
as given below and let us know the results.
i++ -I/home/YourPath/intelFPGA/18.1/hls/include --fpc --fp-relaxed --debug-log -v -march=x86-64 counter.cpp -o test-x86-64
Please try to run it from the terminal without including in the makefile , i.e directly and also including in the makefile. Please let us know the results of each.
Thanks and Regards
Anil
MSura2
As requested I ran the command that you suggested with the given options and this is the result.
i++ -I/opt/intelFPGA/18.1/hls/include --fpc --fp-relaxed --debug-log -v -march=x86-64 counter.cpp -o test-x86-64
Target FPGA part name:  10AX115U1F45I1SG
Target FPGA family name: Arria 10
Target FPGA speed grade: -1
Analyzing counter.cpp
In file included from counter.cpp:1:
In file included from /opt/intelFPGA/18.1/hls/include/HLS/hls.h:11:
In file included from /opt/intelFPGA/18.1/hls/include/HLS/hls_internal.h:5:
In file included from /usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/queue:59:
In file included from /usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/deque:59:
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/stl_algobase.h:59:10: fatal error:
   'bits/c++config.h' file not found
#include <bits/c++config.h>
1 error generated.
I'm not sure about this issue and I've tried to google for it but it's not fixing the issue. Do you have any suggestions?
regards,
Mayank
AnilErinch_A_Intel
Hi
Please let us know which OS version you are using and can you use another version of gcc and try reproducing the issue.
Thanks and Regards
Anil.
MSura2
I'm using Ubuntu 18.04 Bionic and I shall try using gcc version 4 and try and reproduce the error, I don't know if that will have any impacts but we shall see.
Mayank
MSura2
Hi Anil,
I've also seemed to find something relevant, whereby the installation guides you to use only gcc 4.4.7 compilers, but since they are back dated now is it possible to use a new compiler and could you tell me which one would be valid for the HLS Compiler version 18.1.
Mayank
AnilErinch_A_Intel
Hi
You can try using an older version of Ubuntu and a supported version gcc , and that should solve the problem.
There are some methods available online to use the older gcc on newer OS versions.
For supported gcc versions , you can refer to the document for HLS compiler version 18.1
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn-hls-18-1.pdf
Thanks and Regards
Anil
