Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
How to setup Questa Sim license file
lcoon1981
How to setup Questa Sim license file in Windows 10? Encountered below error when try to launch the tool.
Your help is much appreciated.
AR_A_Intel
We do not receive any response from you to the previous reply that I have provided in private message mail. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
lcoon1981
To provide more information.
The eval license should support the Questa.
Also, I did setup the both LM_LICENSE_FILE and MGLS_LICENSE_FILE in the "System Variables", to the License.dat file.
AR_A_Intel
Hi
Could you help re-confirm your environment variable setup again? You need to set your LM_LICENSE_FILE environment variable to point to the license that Intel provides. c:\intel\license.dat or something similar.
You can refer to link on how to set environment variable.
To make this entry, you may perform a windows Search for "System Variables" and then click on "Edit the System Environment Variables" and then click "Environment Variables". Be aware that you must add the entry in System variables, not user variables.
https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/environment-variables.html
Specifying the License for the Questa
https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/specifying-the-license-for-the-software.html
Please note that you need to add the license file name to the environment variable path, not just the directory.
lcoon1981
Here is the snapshot of my setup. I think it is correct. Can you help to check?
lcoon1981
Is there any update? Is my LM_LICENSE_FILE setup correct in the System variables?
Sahil_Honeywell
I am having the exact same issue. I changed the Environment Variables as per instructions but still having same problems.
AR_A_Intel
Hi
@Sahil_Honeywell@lcoon1981 . Could you provide details for checking?
License.dat file:
Name :
Email Address :
Company Name :
Company Address :
NICID(Mac Add) :
For privacy, reply/attach file in private message.
Sahil_Honeywell
License.dat file: (Attached in zip file)
Email Address : Sahil.Bhat@Honeywell.com
Company Name : Honeywell
Company Address : 2101 City West Blvd Houston TX 77042
NICID(Mac Add) : 98-E7-43-7A-1A-AE
lcoon1981
AR_A_Intel
We PM you another private message. Hope you received it.
Sahil_Honeywell
Not received any message. Inbox is empty.
AR_A_Intel
Done PM another message to @Sahil_Honeywell
AR_A_Intel
