Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
I am getting an Error while using Intel FPGA SDK for emulator Compiling for Emulation .... /usr/bin
Irfan191
This is the errorThis is the error
BoonBengT_Altera
Hi @Irfan191,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Could you let us know which version of OpenCL that you are compiling with? Also which sample design that you are building? As well as the command used to build.
Those information would be useful to help us understand the situation further.
Hope to hear from you soon.
Note: is it correct to say you are using Windows with WSL? Suspect based on the error message it may be some missing/corrupted library during installation.
Best Wishes
BB
Irfan191
Thank You for the reply the version of Opencl and SDK I am using are as follow:
Standard edition SDK: AOCL-19.1.0.670-linux.tar
The Command use to build was ./setup.sh
Version of Opencl: intel-opencl-icd is already the newest version (23.43.27642.40-1ubuntu3). I have use this command to install Opencl (sudo apt install intel-opencl-icd)
Ubuntu 24 is my operating system.
I have set the environment variables as per the given documentation in the SDK
Basically I am looking forward to use the emulator in the SDK to test my machine learning compiler generated Opencl codes.
BoonBengT_Altera
Hi @Irfan191,
Noted with thanks on the details for the environment and OS setup.
And thanks for the patients as due to holiday season there maybe some delayed in the response, but rest assured that we are still looking into your issues.
As OpenCL tool has been deprecated, we would advise to check out our latest oneAPI tool replacement, more details of the product can be found below:
- https://www.intel.com/content/www/us/en/developer/tools/oneapi/fpga.html
- https://www.intel.com/content/www/us/en/support/programmable/support-resources/guided-journey/agilex5/oneapi-fpga.html
However we would still try our best to support your doubts on OpenCL.
Hence would recommend to check on the following:
- can you please run and share the output of the 'aocl diagnose' command
- there should be a sample design available somewhere in the following path (<path_to_exm_opencl_hello_world_x64_linux_<version>>/hello_world), can you please try compiling that instead.
Best Wishes
BB
Irfan191
when running the example
Irfan191
I will let you know soon. Bit busy with other things
BoonBengT_Altera
Hi @Irfan191,
Thank you for the patients, after some alignment we suspect that the culprit might be the missing GCC compiler which the OpenCL may required for emulation, hence would suggest to check of the gcc is install and also the required minimal version for the compiler compatibility with the link below:
- https://www.intel.com/content/www/us/en/docs/programmable/683188/21-3/gcc-requirement.html
Once correct GGC version is installed would recommend to source the 'init_opencl.sh' script to set/re-set the environment variable to ensure all is correct. The script can be found in the opencl installation path.
Hope that clarify
Best Wishes
BB
BoonBengT_Altera
Hi @Irfan191,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
Irfan191
yet to test once tested I will let you know thank you for being there. Hopefully I will test it on this week
BoonBengT_Altera
Hi @Irfan191,
Noted and thanks for the updates, sure please take your time.
Unfortunately we are not able to keep the case open for long. However you can still reopen the case anytime you see the issues persist. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
