Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
I use for an old application (FPGA EP1K50) soft Quartus II v4.1. Can't upgrade to a newer version because result of the compilation then exceeds capabilities of the component. Can you please tell me how to recover a license? Thanks in advance. Regs.
JOliv64
I have twice applied for a license via the Legacy License Generator by indicating the NIC of my machine. The 2 requests failed :
There is an issue in generating the license for this provided NIC/Host ID.
Please check your NIC/Host ID and try again. If you still encounter problems, please contact our customer support.
Olivier Jacquemont
Firmware dev
Itron
1 avenue des temps modernes
86360 CHASSENEUIL DU POITOU   FRANCE
Email : olivier.jacquemont@itron.com
Vicky1
Please go through the below old thread & try again,
https://forums.intel.com/s/question/0D50P00004LH4vA/cant-get-new-quartus-web-50-license
if you still face any issue please provide the screenshot.
Vicky
JOliv64
Hi Vicky, Unfortunately I still have not received a license. I tried again following your instructions and got this message at the end of the procedure : [cid:image002.png@01D57D1F.A436F160] But I have not received anything since. I'm listening to you. Thanks in advance. Regards. [http://brand.itron.com/wax.axd?ua=aHR0cDovL21hcmtldGluZy5pdHJvbi5jb20vY2FtcGFpZ24vcmliYm9uX2xvZ29fcmdiXzgxaC5qcGc=&c=CV$bgIHzeYxc1BOvXdNxEQ3C&h=qa5U4gubTZtxlKRgGYQehOHJFxM=]<https://www.itron.com/> Olivier JACQUEMONT Développement logiciel ITRON France BP 23 1 avenue des temps modernes 86361 Chasseneuil du Poitou Phone : 33 (0)5 49 62 70 84 mailto:olivier.jacquemont@itron.com
Vicky1
Please attach this message again we are unable to see it in community, you can attach screenshots in word file also & ensure it after posting..
Vicky
JOliv64
Hi Vicky,
Thanks in advance.
Regards.
Vicky1
Have you resolved the issue?
Should I consider that case to be closed?
Vicky
Vicky1
Glad to know that our suggestion helped to resolve your issue.
Vicky
