Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
Image Stitch FPGA IP
Matt_P
Hello Community,
I'm looking for further documentation on "Image Stitch FPGA IP" for a 2-camera application. I've only been able to find a brief for it (https://cdrdv2-public.intel.com/618542/Image%20Stitch-Solution%20Brief-V0-2.pdf).
It seems this IP may have been encompassed in the 'Video and Vision Processing Suite' and it will suffice, but curious to understand if you're aware of or would recommend more!
Wincent_Altera
Hi Matt,
You are right those function is covering in video and vision suite design example.
BUT, if you need real specific implementation for Image Stitch as per mentioned in the brochure ,
I advise to contact direct Altera Sales FAE/Distributor to get it.
Let me know if there is any further clarification is needed.
Wincent_Altera
Wincent_Altera
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket. Nevertheless, you can still response to the forum and I will be available to assist you.
Wincent_Altera
Matt_P
Thank you for following up.
I don't have any further questions at this time - I've seen the Warp IP among other things within the VVP Suite and will continue to work within.
