Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1343 Discussions
Installation Flow: OneAPI BaseKit + Quartus + Arria10GX on our local machines Ubuntu 20.04, 18.04.
Paul_Allaire_bcom
We are a team of FPGA developers trying to work with oneAPI DPC++ on our Arria10 GX board.
We have two machines at our disposal. One with Ubuntu 20.04 installed, the other one with Ubuntu 18.04.
We are encountering problems during the installation process.
Please find bellow our installation flow on our first machine (Ubuntu 20.04):
First, we installed the Intel® oneAPI Base Toolkit version (2023.0.0-25537) on our local machine using the APT-Package Manager.
https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html?operatingsystem=linux&distributions=aptpackagemanager
Then we tried to install from the APT-Package Manager the following package:
intel-oneapi-intelfpgadpcpp-a10gx-s10sx.
However this package seems outdated since its dependencies are broken.
On our second machine (Ubuntu 18.04), we tried the same installation flow:
Then we tried to install from the APT-Package Manager the package:
Which didn't work either.
We have provided in the attachment :
-The error logs that are yield to us when we try to install the pacakge intel-oneapi-intelfpgadpcpp-a10gx-s10sx on our Ubuntu 18.04.
Thank you in advance for the help you will prodvide us.
Paul Allaire, FPGA designer at b<>com.
hareesh
please give me some time i need to discourse with my team about this issue.
hareesh
please check bellow article. it may be helps you. and before installing packages please check required amount of disk space is available or not.
https://oneapi-src.github.io/oneapi-ci/#linux-apt
hareesh
any update on your issue?
olivierweppe
Hi hareesh,
Paul and I are on the same team.
We tried the apt intallation on a different server using a different network connection, but we still get the same issue. The packages are downloading fine at first, but when reaching amd64 intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part2-2021.1.1, there are errors with the downloaded packages:
Get:77 https://apt.repos.intel.com/oneapi all/main amd64 python3-opae.pac-sign amd64 1.0.3-1 [2566 kB]
Get:78 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part1-2021.1.1 amd64 2021.1.1 [2364 MB]
Get:79 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part2-2021.1.1 amd64 2021.1.1 [265 MB]
Err:79 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part2-2021.1.1 amd64 2021.1.1
File has unexpected size (4560192204 != 265224908). Mirror sync in progress? [IP: 23.72.203.93 443]
Hashes of expected file:
- SHA512:8bc1c8b9560376831ec6866cce22344b0fd7ace39ce407e78620804ce878e99062d60603d64e31c090400d6ab1049e29ce8ce4785141722a793bbe65ff1de989
- SHA256:19270f56e5e4fa9fecb1f6df35463cb13c3a654411d0c2762348a0f1959b396c
- SHA1:104acbe67337f9cb9df1359c18a4f64af6d93c43 [weak]
- MD5Sum:2fc2f53aa3a10ed13f7f62c238c6c460 [weak]
- Filesize:265224908 [weak]
Get:80 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part3-2021.1.1 amd64 2021.1.1 [407 MB]
Err:80 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part3-2021.1.1 amd64 2021.1.1
File has unexpected size (4701816882 != 406849586). Mirror sync in progress? [IP: 23.72.203.93 443]
The packages in error are amd64 intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part2-2021.1.1, part3 and part4.
It seems the sizes declared in the apt repository of OneAPI are wrong for these packages, so the apt tool won't continue with installation.
hareesh
thank you for updating. please give me some time i am trying to duplicate your issue.
hareesh
i am trying to duplicate the issue. but i am also facing some issues. please give me some more time. and share your os version details.
olivierweppe
thanks for your feedback.
We made our installation attempts on servers running on Ubuntu 18.04
hareesh
please check your hardware requirement and memory.
once check bellow article. in this you can find out hardware requirement details.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-oneapi-dpcpp-system-requirements.html
olivierweppe
thanks for this information.
Just to be sure, can you confirm that you managed to install the complete compilation suite of oneApi for FPGA from scratch from Intel public apt repository without any problem on Ubuntu?
hareesh
sorry for the delay.
I trying to install those packages. at installation time I missed some packages. mostly I try to give a solution EOD or tomorrow.
hareesh
I am also facing issues installing APT packages. I need to discourse with another team about this.
i think you also facing same issue. Is it right?
olivierweppe
Yes,  one part of the problem is that on ubuntu 20.04, there is a dependency with python-jsonschema that cannot be satisfied.
The second part is that, even without this dependency issue (like on ubuntu 18.04), there is a mismatch with the size of some packages. Just running the "apt download intel-oneapi-intelfpgadpcpp-a10gx-s10sx-quartus-part2-2021.1.1" command gives an error:
hareesh
I need to discourse offline with you. can you please tell me when you will be available to arrange a call?
hareesh
As you asked, I arranged a call. please check and update me.
hareesh
in the below link, you can find all training modules and documents related to oneAPI. please go through the training modules.
https://devcloud.intel.com/oneapi/get_started/
hareesh
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
hareesh
hi,
hareesh
