Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1340 Discussions
Issue Generating PHY Example Design for 8 GTs and 16 GTs for NRZ Configuration
Pardeepkumar
I'm currently working on generating the PHY example design for lower data rates, specifically 8 GT/s and 16 GT/s (haven't tried 2.5 GT/s or 5 GT/s as of now), for the development kit testing. I'm using Quartus Prime Pro version 24.3.1, and have tried this on both Linux and Windows platforms.
While I'm able to configure and generate the IP with the desired settings successfully, I'm encountering an issue when attempting to generate the example design. Upon clicking the option to generate the example design, I receive the following error:
Error: directphy_f_0: You must select one of the Example Design Options and enable the checkbox before clicking Generate Example Design button.
Error: Failed to generate example design example_design to: C:\Users\user\Desktop\Projects\directphy_f_0_example_design.
Pardeepkumar
This is a gentle reminder that we have not yet received any input regarding the issue mentioned earlier.
We request you to kindly provide a solution on an urgent basis, as it is impacting our ongoing work.
Your prompt support in this matter would be greatly appreciated.
WZ2
Hi there,
If you want to use the example design in this IP, you need to select the options under the "Example Design" subsection. For example, make sure to check the option like "Acknowledgement for Example Design Generation" before clicking the "Generate Example Design" button.
WZ
