The server is running and checked it on imtools.
Warning (292000): FLEXlm software error: No SERVER lines in license file. Feature: quartus License path: D:\flexlm\1-PDLTRL_License.dat; FlexNet Licensing error:-13,128 For further information, refer to the FlexNet Licensing documentation, available at "www.flexerasoftware.com"..
Error (119013): Current license file does not support the 10M40DAF672C7G device. Go to the Self-Service Licensing Center on the Intel FPGA website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html).
Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 4911 megabytes
Error: Processing ended: Thu Feb 28 10:28:47 2019
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 260 warnings
Have you tried the quartus license without the other ones ? This way you can see where your problem resides.
Combining files does not work, I think you need to use ; or : between the different file names if you want to combine license files.
Johi.
Mine is a floating lic file. If I comment out the 'USE ERVER' it brings up product
FIR Compiler, NCO compiler, FFT/IFFT.
If I do not comment it out it brings up nothing. also when I try to compile a max 10 device it does not work. It throws:
Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 4944 megabytes
Error: Processing ended: Mon Mar 04 10:02:47 2019
Error: Elapsed time: 00:00:02
Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 259 warnings
I finally got in contact with Altera and the lic is fixed.
