Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1340 Discussions
NIOS and TSE license issue Can't open encrypted VHDL or Verilog HDL file. Current license file does not contain a valid license for encrypted file.
JMedi
We have been using Quartus for several years.
Lately we have updated to Quartus Prime 18.1.
While we were buying the licenses we have been using a license from an evaluation kit. We have generated time limited sof version without problems.
We now have new licenses for Quartus, NIOS and TSE. These can be seen in Quartus (attached image)
When we try to compile it gives us an error, as if we had no license (NIOS, TSE):
Error (10003): Can't open encrypted VHDL or Verilog HDL file "....../NIOS_cpu_cpu.v" -- current license file does not contain a valid license for encrypted file
"......./altera_eth_tse_mac.v" -- current license file does not contain a valid license for encrypted file
(And more like this)
Our Flex server version is v11.14.0.2
Juan Antonio
AR_A_Intel
Hello
Welcome to INTEL forum. May I know, have you re-generate your license file? If not, could you help to re-generate your license file in Self Service Licensing Center and try it. Only the license administrator can re-generate the license file.
Guidance: https://fpgasupport.intel.com/AlteraLicensing/license/index.html --> Licensing Center Home --> Computer and License Files --> Select a computer to generate a new license file.
JMedi
Yes, I re-generated my license file. I can see the license in the license manager. Could you see the attached image in my previous message?
I repeat the test using the last license file (see attached image).
Juan Antonio
AR_A_Intel
Hi
Thanks for update. Could you provide the full error.log file for further investigation?
JMedi
Attached you can find it.
In this file, you can see lines like this:
Error (10003): Can't open encrypted VHDL or Verilog HDL file "D:/Q18/trunk/NIOS/synthesis/submodules/NIOS_cpu_cpu.v" -- current license file does not contain a valid license for encrypted file
Error (10003): Can't open encrypted VHDL or Verilog HDL file "D:/Q18/trunk/NIOS/synthesis/submodules/altera_eth_tse_mac.v" -- current license file does not contain a valid license for encrypted file
Juan Antonio
AR_A_Intel
Could you help check and upgrade the client PC to newest version of alterad daemon v11.16.1 and try it.
The daemons can be downloaded from the following link:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/licensing/daemons.html
JMedi
Thanks, It solved our issue.
Juan Antonio
AR_A_Intel
Sounds good, hope everything is working well at your side. If you don’t have any further question, I will close this issue. Thanks
NaveenParameswara
Can you pls help, Im using as FLoating License server
NaveenParameswara
Attaching the error screen shots. FR
