Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1337 ディスカッション
Quartus 20.1 software licensing issue
IDeyn
新規コントリビューター III
2,531件の閲覧回数
Hi all!
I have an issue with Quartus 20.1 software licensing.
The same project in Quartus 18.0 compiles successfully.
I checked from the Self Service Licensing Center that license file contains no expired IP cores and tools.
Ivan
0 件の賞賛
1 解決策
IDeyn
新規コントリビューター III
2,448件の閲覧回数
Hello everyone!
In the end, everything worked out, and the problem was resolved.
It is not known for certain whether one or all of them helped.
report .asm.rpt was not generated at all and there was nothing in the error.log.
I did the following:
1. Reinstalled the license daemon from this link https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/licensing/daemons.html
2. Recreated the license file again (it had a lot of duplicates). I left the most recent files in it.
3. Configured the server again using this video https://www.youtube.com/watch?v=llLaWatUbe8 and this troubleshooter helps https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ts-index/lic.html
4. I also configured the firewall again (this turned out to be critical on one of the machines)
Together, these actions helped me to solve the problem. I hope that these actions will help someone else.
PS: Thank you for your responsiveness, AR_A_Intel.
Ivan
元の投稿で解決策を見る
6 返答(返信)
AR_A_Intel
従業員
2,515件の閲覧回数
Hello
Welcome to INTEL forum. Maybe the issue caused by corrupt or incomplete license file. Could you help to clear out your web browsers cache/temporary internet files and regenerate back new license using Google chrome.
Regenerate license: Log on to the Intel Self Service Licensing Center. Navigation:
https://fpgasupport.intel.com/Licensing/license/index.html
--> Self Service Licensing Center --> Licensing Center Home --> Computer and License Files --> Select a computer to generate a new license file.
IDeyn
新規コントリビューター III
2,489件の閲覧回数
Hi AR_A_Intel!
Thank you for your answer.
Well, the error occurs at the assembler stage. It is worth noting that if I delete all licenses in the license.dat file and leave only server initialization, the error will be similar.
And also, that license file works well with Quartus 18.0, as I said.
Ivan
AR_A_Intel
従業員
2,469件の閲覧回数
To narrow down the issue. Can you provide information on your?
1) Debug/error.log file
2) License.dat file
3) Error message screenshot
4) Screenshot of Quartus >> tools >> license setup
5) assembler report .asm.rpt file
•           The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.
And for privacy, you can reply/attach your file in private message.
IDeyn
新規コントリビューター III
2,449件の閲覧回数
Hello everyone!
Ivan
AR_A_Intel
従業員
2,429件の閲覧回数
Sounds good, thanks for sharing and hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
IDeyn
新規コントリビューター III
2,423件の閲覧回数
返信
