Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
Quartus II 3.0 installer
Eng_Manuel
Good morning to all,
I'm looking for the installer for Quartus II version 3.0.
Do you know where may I download it?
Thank you
Manuel
SyafieqS
Sadly I don't have the archive due to EOL-ed. May I know what device are you targeting?
3.0 is pretty old and I suggest to use recent supported Quartus to avoid any issue.
_AK6DN_
Valued Contributor II
That is a ~really~ old version. Even the Internet Archive only goes as far back as v6.1:
https://archive.org/search?query=subject%3A%22quartus%22
What device(s) do you need 3.0 for? Support for a specific ~old~ device is the only reason to require v3.0.
Eng_Manuel
I need to modify a project based on the EP20K200EF component. In the project I have also a NIOS II part (designed with the 3.0 version). However, I just tried to download the 6.1 version to understand if it is ok for me.
SyafieqS
What device are you using? Is that device at least support 13.1 version? 6.0 is pretty old you may use it but at your own risk as there is no longer supported.
SyafieqS
Let me know if there is any update from previous reply
FvM
I see that APEXIIKE and APEX20K series are last supported in Quartus 9.0.
Frank
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
