Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
Quartus install on Ubuntu
JSYOO
Hi I am trying to install Quartus 23.3 on my linux machine.
It uses Intel I9 processor and the OS is Ubuntuo 22.04.4 LTS
"Aborted" message keeps showing up and I don't have any clue how to proceed.
HubertG
Hi JSYOO,
When running the installer, can I suggest not to put ' --target tmp_download '. Instead just run the installer as usual, you may change the desire specified directory in the installer afterwards
Example as below:
I think this will solve your problem. Let me know does it works for your case and if you have further inquiries do not hesitate to ask me
Hubert
JSYOO
Hi Hubert,
I am still facing similar issues without the target specification.
I wasn't sure where is the default extract location is, so I did not do the "sudo ./qinst.sh --help" with the new target location.
But, as you can see in the screenshot, I am still getting the "Aborted" message after doing "sudo ./qinst-linux-23.3-104.run"
The screenshot:
By the way, I could not see your image under "example as below:" line.
So I just removed the target part and did the "sudo ./qinst-linux-23.3-104.run" command.
Junsang
HubertG
Hi JSYOO,
Sorry for the late reply, can you please try out this command below ?
~/Downloads$ ./qinst-linux-23.3-104.run without the "sudo" and "tmp"
Let's see if it works
Hubert
HubertG
Hi JSYOO,
A correction on my statement above & few workarounds that you can try as below :
  1. Option 1
    1. Try key in qinst-linux-23.3-104.run without the "sudo" and "tmp"
  2. Option 2, double click installer in the folder
  3. Option 3
    1. cd to the installer directory
    2. type "./(installer name).run"
    3. Then, press enter
These should be work. Let me know if any of these solves your issue
Hubert
JSYOO
I tried the option 3, but the similar message shows up.
It might be a problem on our end.
RichardTanSY_Altera
Could you try following the steps in this video?
The flow is shown in Windows, but you can also see the respective commands for Linux.
Link: https://www.youtube.com/watch?v=y78XloUJ_x0
User Guide [3.3.1.4. Using CLI Commands]
https://www.intel.com/content/www/us/en/docs/programmable/683472/24-2/using-cli-commands.html
Richard Tan
JSYOO
Thanks for the reference.
I have tried with some different options referring to your links, but I am facing the similar problems.
Junsang
HubertG
Hi JSYOO, I see..okay
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
