Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1175 Discussions
Questa 2021.1, Fatal License Error: Unable to checkout a viewer license
raphiRubi
Two weeks ago I "signed up for Evaluation or No-Cost License" for the "Questa*-Intel® FPGA Starter Edition (License: SW-QUESTA).
The simulator was running perfectly. Using LM_LICENSE_FILE variable.
Yesterday suddenly the following error message appeared (see attachment)
Unable to checkout a viewer license necessary for use of the Questa Intel Starter FPGA Edition graphical user interface. Vsim is closing.
How can I fix this issue.
The License file should be valid for 1 Year though?
Raphael
raphiRubi
Here the erroe message:
# Start time: 10:00:11 on Nov 17,2023
# ** Note: (vsim-8009) Loading existing optimized design _opt2
# ** License Issue: License request for intelqsimstarter feature failed
# ** License Issue: Cannot checkout an uncounted license within a Windows Terminal Services guest session. (C:\licenses\flexlm\LR-146054_License.dat)
# ** License Issue: Cannot find license file. (C:\flexlm\license.dat)
# ** Error: Failure to obtain a VHDL simulation license. Unable to checkout 'intelqsimstarter' license.
# Error loading design
SyafieqS
Few things you can do.
  1. For Questa FSE, have you tried to regenerate the free license again?
  2. To disable internet connection and rerun simulation
  3. Or use diff connection and rerun
Let me know any update.
SyafieqS
Let me know if there is any update.
JP28
I have the same problem. Was there any solution?
BR
