Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1341 Discussions
Questa doesn't recognize the license file
DavidTP
I installed Quartus Prime Edition 21.1 and Questa - Intel FPGA Starter Edition 2021.2
Generated a License with the SSLC and created the enviroment variable LM_LICENSE_FILE.
But when I try to open Questa or do a RTL Simulation from Quartus, it gives a "Fatal License Error", saying: "Unable to chekout a license. Make sure your license file enviroment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmutil lmdiag' to diagnose the problem.", although if I  run 'lmutil lmdiag' in the Windows PowerShell it does detect the license file and shows me it's location.
I had both programs, Quartus and Questa running on another computer, but as I am now using another PC, I have changed the primary computer ID in the license with the SSLC, but it just doesn't work.
Is there any way to get Questa working in this new PC?
AR_A_Intel
Hi
Could you provide the license.dat file for checking? Thanks
You can also reply/attach your file in private message.
AR_A_Intel
Hello
Welcome to Intel forum. Could you help to regenerate again Questa license in SSLC and try it. Before that, can you help clear your web browsers cache/temporary internet files (if possible, shutdown your PC and restart back) and sign back to SSLC (https://licensing.intel.com/eval-free-licenses ) using Google chrome and see how things go.
DavidTP
Hello, that didn't work.
For some reason the computer was no longer active in the SSLC and I couldn't activate it.
In the end I decided to create a new computer and sign up for a free license in that one. Once I got the new license I changed the value of LM_LICENSE_FILE to match the new file, but Questa still can't checkout the license. I can't understand why.
AR_A_Intel
Hi
DavidTP
For anyone reading this, the license was of FLOAT type.
I changed it to a FIXED type, as he told me. Then, after changing the LM_LICENSE_FILE variable and restart the PC, Questa started working just fine.
AR_A_Intel
Thanks for your update, hope all is well. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
