Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1343 Discussions
VHDL pragma --synthesis library ... is unsupported in 20.1 ?
CStra20
See below the output. First line of bsv_pkg.vhd is the embedded pragma --synthesis library bsv
This pragma works in previous version of quartus.
Info: *******************************************************************
Info: Running Quartus Prime Synthesis
  Info: Version 20.1.0 Build 177 04/06/2020 SC Pro Edition
  Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
  Info: Your use of Intel Corporation's design tools, logic functions
  Info: and other software and tools, and any partner logic
  Info: functions, and any output files from any of the foregoing
  Info: (including device programming or simulation files), and any
  Info: associated documentation or information are expressly subject
  Info: to the terms and conditions of the Intel Program License
  Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
  Info: the Intel FPGA IP License Agreement, or other applicable license
  Info: agreement, including, without limitation, that your use is for
  Info: the sole purpose of programming logic devices manufactured by
  Info: Intel and sold by Intel or its authorized distributors. Please
  Info: refer to the applicable agreement for further details, at
  Info: https://fpgasoftware.intel.com/eula.
  Info: Processing started: Mon Jun 8 14:29:22 2020
  Info: System process ID: 217156
Info: Command: quartus_syn --64bit --analysis_and_elaboration --write_settings_files=off onewire
Info: Using INI file /home/chris/opencpi_clean/projects/core/hdl/primitives/ocpi/target-cyclone/quartus.ini
Info: qis_default_flow_script.tcl version: #2
Info: Initializing Synthesis...
Info: Project = "onewire"
Info: Revision = "onewire"
Info: Analyzing source files
Error (17816): VHDL error at bsv_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 1
Error (13827): Ignored construct bsv at bsv_pkg.vhd(161) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 161
Error (17816): VHDL error at fixed_float_types_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 1
Error (13827): Ignored construct fixed_float_types at fixed_float_types_pkg.vhd(35) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 35
Isaac_V_Intel
Hi CStra20,
First some questions to get all the ground of your case.
Did you have W/R permissions to the path that you are using at the project?
Can you try to specify the library in the qsf line that adds the file to the project.
Can you share your project with us to replicate this issue, in case that you can't solve this.
Best regards
Isaac Vazquez
