Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
When using RSU, is it necessary to use an external trigger to trigger the FPGA to load the application image?
Kavin
I got some problems when using RSU in Cycone IV E device:
1: When using RSU, is it necessary to use an external trigger to trigger the FPGA to load the application image?
2: Why can't I get the reason for reconfiguration by reading the register when the application image fails to load and returns to the factory image?
3: The same loading process, why use the avalon-mm interface in the factory image I can not trigger the FPGA to load the application image, but the non-avalon-mm interface can trigger?
