Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1340 Discussions
can not install eclipse(v19.3) with ubuntu18.04
LZhi01
hello, i install eclipse with ubuntu 18.04, when i use eclipse,i got this error message "
root@smart-HP:~/intelFPGA_pro/19.3/nios2eds/bin# ./eclipse-nios2
OpenJDK 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
free(): invalid pointer
" and i can not use eclipse;what can i do next ?
MEIYAN_L_Intel
From the message show you are installing the later version of JDK v8.0, but the version needed for eclipse is JDK v7.0.
Upon checking , there is a customer who face the same problem with you.
Could you try to set the environment variable as link below:
https://wiki.archlinux.org/index.php/Eclipse#Disable_GTK_3
If the problem still persist, please tell me as well.
LZhi01
hello,    thank you email,i change the .ini file as below but,when i click OK button,the eclipse is disappered. i still can not use sbt.
MEIYAN_L_Intel
I am not able to look into the .ini file, could you try to upload the .ini file?
LZhi01
你好,如附件所示,你是否可以远程帮我解决一下?谢谢。
LZhi01
hello,as shown in the attachment,can you help me solve it remotely by teamviewer?thank you
MEIYAN_L_Intel
I had reported this issue to developer. I will reply here once I receive the information from the developer.
MEIYAN_L_Intel
Sorry for late reply.
You might need to try to set environment variable by prepending "SWT_GTK3=0" before starting eclipse.
For your information, Ubuntu is not officaially supported for the Nios II EDS.
