Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
questasim unable to checkout a license
Sri_FPGA
Hi ,
I am trying to install to run a questasim (RTL simulation) in quartus prime lite edition 22.1.
when I try to run the RTL simulation.
Error showing
" unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmultil lmdiag' to diagnose the problem."
But I already downloaded the license from the Intel® FPGA Self-Service Licensing Center .
(I used my PC NAME , NIC ID , FIXED Type License). And set the environmental variable ( image attached ).
In quartus prime software also I license path is detected ( image attached).
I try to run the questasim directly from the location "C:\intelFPGA_lite\22.1std\questa_fse\win64".
same error is showing.
Please tell anyone where I done the mistake.
Thanks for your time
AR_A_Intel
Hi.
There is an issue with license generator recently. The license generation issue has been resolved. A fix has been deployed. Could help to request/regenerate again a new license file in self-service licensing center and try it.
AR_A_Intel
We have not heard from you and I hope that my last note in private message mail clears up this matter and it can now be move forward. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
jster
Copy from my original contribution shown below.  Hope it helps:
I added my PDF steps I followed to get there. Mostly followed the great youtube guide source which might get you there pretty fast is: https://www.youtube.com/watch?v=e5kHFiAVcRI
Ok,,, I think my linux system is all configured up to start coding some FPGA finally.
