Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1340 Discussions
(vcom-1598) Library "altera_fp_functions_1914" not found.
Nag_t
Hi All,
I am using Quatuts standard 22.4 version tool for code generation and  wile iam trying to simulate generated code using Questasim observed below error.
 # -- Loading package STANDARD
# ** Error:
Altera/Arria_10/unspecified/F200/synth/alterafpf_mul_double.vhd(6):
 Could any one share your thoughts for causing this error .
Nagapavani
FvM
Happens if simulation IP hasn't been generated or was generated for a different IP version.
SyafieqS
You can regenerate the IP and rerun the simulation. Give it a try and see if that resolve the issue.
SyafieqS
May I know if there is any update?
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer, kudos and rate 5/5 survey.
IntelSupport
Community Manager
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
