Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1236 Discussions
Altera Monitor Program hangs
Hi I'm trying to use the altera monitor program to debug.
But it hangs while I'm loading source code. Here's what It says in the Info and Errors message box:
Compiling source files...
nios2-elf-as --gstabs -I E:/altera/81/nios2eds/components/altera_nios2/sdk/inc E:/Altera/msl/msl_sdk/lab5_rand.s -o E:/Altera/msl/msl_sdk/lab5_rand.s.o
nios2-elf-as --gstabs -I E:/altera/81/nios2eds/components/altera_nios2/sdk/inc E:/Altera/msl/msl_sdk/lab6_b.s -o E:/Altera/msl/msl_sdk/lab6_b.s.o
Linking...
nios2-elf-ld --defsym nasys_program_mem=0x801000 --defsym nasys_data_mem=0x801000 --section-start .exceptions=0x1000020 --section-start .reset=0x1000000 -e main -u main --script E:/altera/81/nios2eds/bin/monitor/build/nios_as_build.ld -g -o E:/Altera/msl/msl_sdk/lab5_rand.elf E:/Altera/msl/msl_sdk/lab5_rand.s.o E:/Altera/msl/msl_sdk/lab6_b.s.o
ELF generated at E:\Altera\msl\msl_sdk\lab5_rand.elf.
nios2-elf-objcopy -O srec E:/Altera/msl/msl_sdk/lab5_rand.elf E:/Altera/msl/msl_sdk/lab5_rand.srec
SREC generated at E:\Altera\msl\msl_sdk\lab5_rand.srec.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloading 00801000 ( 0%)
Downloading 01000020 (48%)
Downloaded 1KB in 0.0s
Verifying 00801000 ( 0%)
Verifying 01000020 (48%)
Verified OK
Connection established to GDB server at localhost:2399
Symbols loaded.
Source code loaded.
INFO: Program Trace not enabled, because trace requires the Nios II processor to be configured with JTAG Debug Level 3.
I don't see any assembly and most of the menu options are disabled. It used to work before, but now it just hangs. Can someone tell me how to solve this?
