Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
De2-115 sram
Hello, I'm having trouble with the university program SRAM core. There's only one option and that is to select the target board (DE2-115). However, when I go to run my C code it always tells me my processor is not responding.
Because I'm simply just trying to get my SRAM to host my C code (so I can use the DRAM for other purposes) I only have a Nios CPU, switches, and the SRAM in my design.
Does anyone know what could be going on or what I should do? Here's everything just for calcification. Also, the system is not accidentally left in a constant reset state; although that has happened to me before!
/////////////////////////// VERILOG ////////////////////////////////
module dram_system(
CLOCK_50,
SW,
SRAM_DQ,
SRAM_ADDR,
SRAM_CE_N,
SRAM_WE_N,
SRAM_OE_N,
SRAM_UB_N,
SRAM_LB_N);
input CLOCK_50;
input [17:0] SW;
inout [15:0] SRAM_DQ;
output[19:0] SRAM_ADDR;
output SRAM_CE_N;
output SRAM_WE_N;
output SRAM_OE_N;
output SRAM_UB_N;
output SRAM_LB_N;
dramImageCPU dCPU (
.clk_0(CLOCK_50),
.reset_n(~SW[17]),
.in_port_to_the_switches(SW[15:0]),
.SRAM_ADDR_from_the_sram_0(SRAM_ADDR),
.SRAM_DQ_to_and_from_the_sram_0(SRAM_DQ),
.SRAM_CE_N_from_the_sram_0(SRAM_CE_N),
.SRAM_WE_N_from_the_sram_0(SRAM_WE_N),
.SRAM_OE_N_from_the_sram_0(SRAM_OE_N),
.SRAM_UB_N_from_the_sram_0(SRAM_UB_N),
.SRAM_LB_N_from_the_sram_0(SRAM_LB_N));
endmodule
///////////////////////////// NIOS /////////////////////////////
# include <iostream>
using namespace std;
int main (void) {
cout << "Running..." << endl;
return 0;
-- Like I said, I just want it to run:
bash-3.1$ nios2-download -g *.elf
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
:(:confused::cry::mad:
I tried to make a custom SoPC module for the SRAM but I don't think I really know what I'm doing well enough for that, it didn't work. Now, this isn't really all that big a deal project wise since I'm just using the SDRAM controller for other portions but I do need the SRAM to work eventually so I'm open to ideas.
Ideally, I would like to make my own core anyway but I don't really know how to do it. Thanks
My apologisies to Terasic and people interested:
once i have lowered clock within access time of sram on the board everything was fine. Still can not explain why original Terasic design did not work.
---below my original answer: ----
I am pretty sure that original IP from terasic “Terasic_sram “ has some problem. I had simple test writing and reading values from SRAM and it failed. Then I took one of the original sample design from de2-115 and tried to make simple “hello world”. It did load when code was in on chip or sdram. It did not load when i asked to download code to sram. In addition to this I have tried to run the same sram test (code in sdram) and it failed. My simple memory tests works nicely on all other boards.
Zbigniew , sydney
Could you please tell me your timing parameters. I could not get it working on DE2-115 with the following for the Terasic SRAM IP:
Setup 0
Read Wait 1
Write Wait 0
Hold 0
Read Latency 0
