Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
Dedicated clock pin on DE2
名誉分销商 II
3,425 次查看
Hi
Is there a way to get a clock signal from an external device into any PLL clockin on the DE2?
I've read that those clockin must be from a dedicated clock, but if I search in the manual of DE2 and the pin planer for the EP2C35F672C6(the FPGA on the DE2), those pins are already use by switches and stuff, not a single one avaible on the I/O connector.
How can I set up the PLL to use one of this I/O in the 40 pin connector?, or How can I get into the PLL a signal coming from other device?
Thanks a lot!
0 项奖励
6 回复数
名誉分销商 II
1,021 次查看
Please review the schematic for the DE2. There are several versions of this board (DE2, DE2-70, DE2-115)
On the DE2, there is an SMA on the board, it connects to pin P26 which is called CLOCK_EXT in the schematic and connects to CLK7 on the FPGA.
You should be able to use that.
Cheers,
Dave
0 项奖励
名誉分销商 II
1,021 次查看
Thanks dwh
My board says just DE2, so I'll use the SMA...
Is anything else for configuration to use this for the PLL?
I mean, I've created a PLL with the megafunction where do I tell it to use CLK7 or its just by setting the PLL clockin port to CLOCK_EXT in the pin planer?
0 项奖励
名誉分销商 II
1,021 次查看
--- Quote Start ---
--- Quote End ---
You can call the clock port/net anything you like, just so long as you set the pin to P26. For example, I call it clk_sma in my top-level design file.
You then connect that net name as the clock input to your PLL megafunction instance.
I would recommend creating a counter and use it to blink an LED once per second. If you have the PLL configured correctly, then it'll be pretty obvious.
This thread:
http://www.alteraforum.com/forum/showthread.php?t=33462
has an example zip file called de2_basic.zip. Download it and follow the instructions. It doesn't have a PLL in the example, but you could add it easily enough.
Cheers,
Dave
0 项奖励
名誉分销商 II
1,021 次查看
Thanks a lot!
The LED idea is good for testing I guess.
And thanks for the zip, I'll check it soon as I arrive to my lab
0 项奖励
名誉分销商 II
1,021 次查看
I can't understand what you want to say in the code word of "PLL"...?
can you please explain?
genemedics (http://www.genemedics.com/growth-hormone/) // genemedics.com (http://www.genemedics.com/estrogen/) // progesterone in men (http://www.genemedics.com/progesterone/)
0 项奖励
名誉分销商 II
1,021 次查看
--- Quote Start ---
--- Quote End ---
PLL = phase-locked loop
http://en.wikipedia.org/wiki/pll
Cheers,
Dave
0 项奖励
回复
