Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Error Message from schematic compilation
Hello I am using the web edition of Quartus 2. I am getting the following error when I try to compile a simple logic schematic.
*** Fatal Error: Access Violation at 0X00FC4DF4
Module: quartus_map.exe
Stack Trace:
0x4DF4 : QTL_ZOFSTREAM::close + 0x34 (ccl_qtl)
0x55F15 : sgn_qic_helper + 0x4A2C5 (synth_sgn)
End-trace
Any help is appreciated thank you.
--- Quote Start ---
--- Quote End ---
I think you should download more modern version quartus web edition (https://www.altera.com/support/software/download/altera_design/quartus_we/dnl-quartus_we.jsp)
The latest Web Edition is Quartus II V9.0 SP2
So it is not realy clear what Quartus version Blue1440 uses as Quartus 2 could mean Quartus II, the oldest Quartus version i know is Quartus II V2.2 dated somewhere around 2003
But i agree it should be mostl likely the latest version
I am using Quartus II 9.0sp2 web edition. I can compile regular vhdl hdl and other general projects but the schematic entry is not compiling. I still do not know what the problem is. Even if I just put an input pin connected to an output pin the same error occurs.
what is the path to your project? be sure to work in a structure that doesn't approach 256 characters, something more like c:\work\altera.
That was funny...did not realize I had such a long file extension. That fixed the problem, thanks for you help.
