Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
FPGA programma
Hallo.
In the line: assign is something wrong. What is the right way for this line?
JackR.
module Lab3 (s ,x ,y ,m );
input s; //[1:0] s; werkt niet.Geeft s,s0 en s1
input [7:0] x;
input [7:0] y;
output [7:0] m;
assign m [7:0] = (~s&x)|(s&y) [7:0], x [7:0], y [7:0];
endmodule
Whitout some explanations on how it is supposed to work (what should it do) it's very difficult to guess what you want.
Hallo amilcar.
Thanks for the replay. It is for a eight-bit wide 2 to 1 multiplexer.
Figure 3. An eight-bit wide 2-to-1 multiplexer.
1. Create a new Quartus II project for your circuit.
2. Include your Verilog file for the eight-bit wide 2-to-1 multiplexer in your project. Use switch sw 17 on the
DE2 board as the s input, switches sw7−0 as the x input and sw15−8 as the y input. Connect the sw
switches to the red lights ledr and connect the outputm to the green lights ledg7−0.
3. Include in your project the required pin assignments for the DE2 board. As discussed in Part I, these
assignments ensure that the input ports of your Verilog code will use the pins on the Cyclone II FPGA
that are connected to the sw switches, and the output ports of your Verilog code will use the FPGA pins
connected to the ledr and ledg lights.
4. Compile the project.
5. Download the compiled circuit into the FPGA chip. Test the functionality of the eight-bit wide 2-to-1
multiplexer by toggling the switch.
Hope this wil help.
JackR.
assign m = s ? x : y;
Thanks a lot amilcar.
Best regards.
JackR.
