Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1235 Discussions
How to see all inputs/outputs in node finder?
SSale9
Right now I'm trying to create a system comprised of multiple modules (new to Verilog), and I can only ever see the nodes in the top-level entity when in the node finder. As an example, I have written something that follows the following structure:
module exampleMod1(a, b, c, d) input a,b; output c,d; always @(posedge clk) begin //processing a and b end endmodule   module exampleMod2(e, f, g, h) input e,f; output g,h; always @(posedge clk) begin //processing e and f end endmodule   module exampleMod3(i, j, k, l) input i, j; output k,l; always @(posedge clk) begin //processing i and j end endmodule
However, if exampleMod1 is my top-level entity (I have selected it as such in the Assignments > Settings > General section) then when I proceed to the Node Finder in my .vwf file and select list, only the nodes in exampleMod1 are shown (a, b, c and d), since it is the top level module. This also means that I can't run a simulation properly, since I can't view the input that I want to as it is neither a or b. How can I correct this to see all inputs and outputs in the project?
AndyN
If I'm understanding what you are trying to achieve, you need to put a top level wrapper above these modules that will instantiate the modules you want. If you just tell it to use exampleMod1 as your top level, it isn't going to include 2 and 3 in the design.
Something like this:
module topWrapper (a, b, c, d, e, f, g, h, i, j, k, l); input a, b, e, f, i, j; output c, d, g, h, k, l;   exampleMod1 mod1 ( .a, .b, .c, .d );   exampleMod2 mod2 ( .e, .f, .g, .h );   exampleMod3 mod3 ( .i, .j, .k, .l );   endmodule
Hope that helps,
Andy
