Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Maximum operating frequency of MAX10
sugi
Sorry for the beginner's question.
I am using MAX10 (10M04SAU324I7G).
This is a single power supply device.
If I input a single-ended clock to this device and output it as it is, what is the maximum frequency of the clock that can be operated?
For example, is it possible up to about 200MHz?
Ash_R_Intel
As per the datasheet, the max fOUT for -7 speed grade device is 450MHz. However, as per the note 29 in the datasheet, the fIN parameter is limited in the Quartus by maximum I/O frequency which is different for each I/O standard. Recommend to run the Timing Analysis and perform IBIS simulation to understand the maximum achievable frequency for your system.
In my opinion, 200MHz should be easily achievable.
Ash_R_Intel
Please refer PLL specifications in the device datasheet:
Intel MAX 10 FPGA Device Datasheet
You can operate the PLL to max 472.5 MHz, depending upon the speed grade.
Regards.
sugi
Thank you for answering.
Is speed grade "7" for 10M04SAU324I7G?
If speed grade: 7, is there no description of the maximum frequency?
For speed grade: 7, maybe 472.5 MHz isn't possible, right?
I would like to know if a minimum of 200MHz is possible even with speed grade: 7.
Ash_R_Intel
