Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1203 Discussions
Quartus Prime Lite 19.1 University Program VWF simulation error
Mnauel13
Hola con todos, tengo instalado Quartus en debian, y al momento de simular en "University Program VWF" se queda estancado y no termina el proceso. La verdad no tengo ni idea de como solucionar
Determining the location of the ModelSim executable...
Using: /home/manuel/intelFPGA_lite/19.1/modelsim_ae/linuxaloem/
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=vhdl --write_settings_files=off reg_s_p1 -c reg_s_p1 --vector_source="/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/Waveform7.vwf" --testbench_file="/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/simulation/qsim/Waveform7.vwf.vht"
Info: *******************************************************************Info: Running Quartus Prime EDA Netlist Writer Info: Version 19.1.0 Build 670 09/22/2019 SJ Lite Edition Info: Copyright (C) 2019 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and any partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details, at Info: https://fpgasoftware.intel.com/eula. Info: Processing started: Mon Mar 18 01:01:27 2024Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=vhdl --write_settings_files=off reg_s_p1 -c reg_s_p1 --vector_source="/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/Waveform7.vwf" --testbench_file="/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/simulation/qsim/Waveform7.vwf.vht"Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=on --flatten_buses=off --tool=modelsim_oem --format=vhdl --output_directory="/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/simulation/qsim/" reg_s_p1 -c reg_s_p1
Info: *******************************************************************Info: Running Quartus Prime EDA Netlist Writer Info: Version 19.1.0 Build 670 09/22/2019 SJ Lite Edition Info: Copyright (C) 2019 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and any partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details, at Info: https://fpgasoftware.intel.com/eula. Info: Processing started: Mon Mar 18 01:01:28 2024Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=on --flatten_buses=off --tool=modelsim_oem --format=vhdl --output_directory="/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/simulation/qsim/" reg_s_p1 -c reg_s_p1Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.Info (204019): Generated file reg_s_p1.vho in folder "/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/simulation/qsim//" for EDA simulation toolInfo: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning Info: Peak virtual memory: 1101 megabytes Info: Processing ended: Mon Mar 18 01:01:28 2024 Info: Elapsed time: 00:00:00 Info: Total CPU time (on all processors): 00:00:00
**** Generating the ModelSim .do script ****
/home/manuel/Documentos/Quartus projects/ejemplo2/reg_s_p1/simulation/qsim/reg_s_p1.do generated.
**** Running the ModelSim simulation ****
/home/manuel/intelFPGA_lite/19.1/modelsim_ae/linuxaloem//vsim -c -do reg_s_p1.doCaptura desde 2024-03-18 01-02-59.png
