Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Quartus on university linux server and students at home
ETang2
I would like that my students can connect from home to the quartus on linux at the university behind a firewall.
Currently we use https://guacamole.apache.org/ as a clientless remote desktop gateway using RDP and it works very fine but we don't have board support.
We have a lot of DE10-Lite boards and lend one to each student.
I'm looking for a procedure to connect from home to the linux server where quartus is and use a DE10-Lite board form home.
Maybe using native RDP or other idea ?
Thanks a lot
Eric
KellyJialin_Goh
Hi.
Greetings and welcome to Intel's forum.
You may check out this link on the steps to set up remote configuration for Linux System: https://www.intel.com/content/www/us/en/docs/vtune-profiler/user-guide/2023-0/configuring-ssh-access-for-remote-collection.html
Here is another Forum link that might be useful on setting up a remote machine: https://community.intel.com/t5/Intel-Quartus-Prime-Software/remote-farm-machine-setup/td-p/1344201
Let me know if you have further questions and hope to hear on your findings.
Thank you.
Kelly
ETang2
Thanks for you answer but the main question for me is usb-blaster support usb rdp redirection?
Eric
_AK6DN_
Valued Contributor II
I have done this before when working from home. Use a VPN, and use Xwindows to connect to the work server running Quartus for compilation and simulations.
Then locally install the Quartus Standalone Programmer tool to program a local board via USB with the image file.
So all the main work can be done on the server, and the local system runs the programmer tool via USB to program the board.
Never tried to use remote USB via RDP. There are some software packages out there that purport to be able to do this.
But much simpler to keep the USB aspect local and use the Intel/Altera standalone programmer tool on the local system.
KellyJialin_Goh
Hi Etang2,
Usb Blaster for Usb rdp redirection is not supported for remote connection. However, remote JTAG is supported for remote FPGA where USB or Ethernet Blaster could be used to interface JTAG to the host PC. Here is the link for your reference: https://www.rocketboards.org/foswiki/Documentation/RemoteDebug?elq_cid=9479505_ts1670901775447&erpm_id=6980624_ts1670901775447
Hope to hear on your findings. Thank you.
Kelly
_AK6DN_
You are overthinking the problem.
The DE10-Lite is a MAX10 based board with no etherNet and no embedded processor.
Giving each student an etherBlaster is IMHO a non-starter.
Just install the standalone license free Quartus programmer tool on each student's home PC and the problem is solved.
KellyJialin_Goh
Thank you for your feedback. Any updates from your end on which method you have applied to access remote connection for the Linux server?
Thank you.
Kelly
KellyJialin_Goh
Thank you.
Kelly
KellyJialin_Goh
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Thank you.
Kelly Jialin, GOH
