Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
TRDB-D5M Camera Example Distortion after no change compile
Hi Guys
I am using a D5M camera with a DE2-115. When I take the example from the D5m CD and straight program it to the board (as in no re-compile), the image is displayed correctly.
If I make absolutely no changes, but I compile the project before programming the sof file; the image then is displayed with green noise.
Please see the two attached pictures: Note these were taken with a phone looking at an LCD monitor displaying the output of the DE2-115.
The first is a more complete shot of the screen and the 2nd is a zoom in on what happens to the edges.
Has anyone had this problem?
Does anyone know how to compile the project without causing this issue?
I emailed terasic support and the problem appears to be when using a updated version of quartus.
The original project was created on Quartus 9.0 and i'm compiling with 10.1sp1.
So in the end the solution is:
--- Quote Start ---
We have to create the clock for D5M_PIXLCLK manually for this demo, please open the DE2_115_D5M_VGA.sdc file and insert the command "create_clock -period 30.0 [get_ports D5M_PIXLCLK]" into Create Clock as shown
--- Quote End ---
See the screen shot.
this fixed it for me, but they also said this:
--- Quote Start ---
You can adjust the D5M_PIXLCLK data until you get the correct output, D5M CCD Input clock frequency is about 25Mhz
--- Quote End ---
Can you please help me by pointing out any solutions for DE2 board? I tried the same you have provided for DE2- 115 and it did not work.
I using DE2 also getting the result of Distortion by quartus 13.0 sp1. How can i solve this problem?
GKara7
I also get the distortion result with Altera DE2 by Quartus 13.0 sp1. How can I solve this problem?
