Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Verilog FSM stuck on one State forever
Fpga_Egr_2025
I am developing a fsm to latch on to incoming data and compute its average in verilog, but my fsm seems to be just stuck at one state.
Although the simulation shows it did shifted perfectly in previous states, but it is stuck at "filter_data_64" state . See complete code below :
`timescale 1ps/1ps
module amf_ctrl #(
parameter data_bits    = 64,
parameter average_cont = 16
    input            clk,
    input            rst,
input            vld,
input           last,
output           rdy,
input [7:0] data_flit,
input [5:0] valid_bytes,
output [7:0] filter_data_o,
output           done
reg [7:0] data_buff [data_bits-1:0];
reg [data_bits-1:0] byte_cont;
reg [7:0] avg_cont, byte_cont_64, filter_data;
reg [3:0] state;
    reg [3:0] nextstate;
reg [7:0] r0, r1, r2, r3, sum_reg;
reg [5:0] valid_no;
reg done_sig, rdy_sig, vld_dly, vld_pe, byte_64_en;
    assign done = done_sig;
assign filter_data_o = filter_data;
assign rdy = rdy_sig;
parameter idle = 4'b0000, buffer_data = 4'b0001, buffer_data_1 = 4'b0010, filter_data_state = 4'b0011;
parameter Avg_cal = 4'b0100, Sum_data = 4'b0101, Shift_data = 4'b0110, Result_data = 4'b0111;
parameter filter_data_64 = 4'b1000, Sum_data_64 = 4'b1001, Shift_data_64 = 4'b1010, Result_data_64 = 4'b1011;
always @ (posedge clk) begin
vld_dly <= vld;
end
// Detect no of valid Bytes //
always @ (posedge clk or negedge rst) begin
     if (~rst) begin
             valid_no <= 5'b00000;
byte_64_en <= 1'b0;end
else if (last) begin
             valid_no <= valid_bytes;
  if(valid_bytes == 0)
             byte_64_en <= 1'b1;end
else begin
          byte_64_en <= 1'b0;
         end
end
always @(posedge clk or negedge rst)
      if ((~rst)||(byte_cont==data_bits-1))
      byte_cont <= 0;
else
    if (!vld & vld_dly) begin
        byte_cont <= byte_cont + 1;
    data_buff[byte_cont] <= data_flit;
      end
   always @(posedge clk) begin
   if (~rst) begin
       done_sig  <= 1'b0;
   rdy_sig   <= 1'b0 ;
   sum_reg   <= 8'h00;
   filter_data <= 8'h00;
   avg_cont    <= 8'h00;
   state <= idle;
end
    else begin
          case(state)
idle:begin
    if(vld)begin
   rdy_sig <= 1'b1;
                           nextstate <= buffer_data;
end
else if (last)begin
    rdy_sig  <= 1'b0;
nextstate <= filter_data_state;end
    else begin
  rdy_sig <= 1'b0;
  nextstate <= idle;end
    end
buffer_data:begin
           rdy_sig <= 1'b0;
           nextstate <= idle;
                     end
                    filter_data_state:begin
  //if(byte_64_en)begin
     //rdy_sig <= 1'b0;
     //avg_cont     <= average_cont;
                         //byte_cont_64 <= data_bits - 1;
//nextstate <= filter_data_64;end
  //else if (byte_64_en)begin
  //else begin
     //rdy_sig <= 1'b0;
nextstate <= Avg_cal;//end
  end
  Avg_cal:begin
  if(valid_no == 0)begin
                         done_sig <= 1'b0;
nextstate = idle;
end
  else begin
     done_sig <= 1'b0;
     r0 <= data_buff[valid_no];
                         r1 <= data_buff[valid_no - 1];
                         r2 <= data_buff[valid_no - 2];
                         r3 <= data_buff[valid_no - 3];
                         valid_no <= valid_no - 4;
nextstate = Sum_data;end
  end
  Sum_data: begin
        sum_reg <= r0 + r1 + r2 +r3;
nextstate <= Shift_data;
end
                     Shift_data: begin
        sum_reg <= sum_reg >> 2;
nextstate <= Result_data;
end
                     Result_data: begin
        filter_data <= sum_reg;
                            done_sig <= 1'b1;
                            end
filter_data_64:begin
      if(avg_cont == 0)begin
         done_sig <= 1'b0;
     nextstate <= idle;
end
      else begin
     done_sig <= 1'b0;
r0 <= data_buff[byte_cont_64];
r1 <= data_buff[byte_cont_64 - 1];
r2 <= data_buff[byte_cont_64 - 2];
r3 <= data_buff[byte_cont_64 - 3];
                             byte_cont_64 <= byte_cont_64 - 4;
avg_cont <= avg_cont - 1;
nextstate <= Sum_data_64;end
  end
                     Sum_data_64: begin
          nextstate <= Shift_data_64;
       end
                     Shift_data_64: begin
            nextstate <= Result_data_64;
        end
                     Result_data_64: begin
                            done_sig <= 1'b1;
                            end
  endcase
 end
end
endmodule
/* Verilog test bench : it simulates AXI slave as per document "AMBA® 4 AXI4-Stream Protocol Version: 1.0 Specification" */
`timescale 1ps/1ps
module tb_amf_ctrl();
reg tb_clk; // To drive input "d" of the DUT
reg tb_rst; // To drive input "en" of the DUT
reg tb_vld; // To drive input "rstn" of the DUT
reg tb_last; // To ensure q has not changed when en=0
wire tb_rdy; // To tap output "q" from DUT
wire tb_done;
reg [7:0] tb_data_flit;
reg [5:0] tb_vld_bytes;
wire [7:0] tb_filter_data_o;
amf_ctrl DUT (
                      .clk(tb_clk),
  .rst(tb_rst),
  .vld(tb_vld),
  .last(tb_last),
  .rdy(tb_rdy),
  .data_flit(tb_data_flit),
  .valid_bytes(tb_vld_bytes),
  .filter_data_o(tb_filter_data_o),
  .done(tb_done)
// Clock //
initial tb_clk = 0;
  always #5 tb_clk = ~tb_clk;
initial begin
    tb_rst  <= 1'b0;
tb_vld  <= 1'b0;
tb_last <= 1'b0;
tb_data_flit <= 8'h00;
tb_vld_bytes <= 6'b000000;
#30;
tb_rst <= 1'b1;
#10;
//1st byte
tb_vld  <= 1'b1;
tb_data_flit <= 8'h11;
#20;
tb_vld  <= 1'b0;
#20;
//2nd byte
tb_vld  <= 1'b1;
tb_data_flit <= 8'h02;
#20;
tb_vld  <= 1'b0;
#20;
//3rd byte
tb_vld  <= 1'b1;
tb_data_flit <= 8'h03;
#20;
tb_vld  <= 1'b0;
#20;
//4th byte
tb_vld  <= 1'b1;
tb_data_flit <= 8'h04;
#20;
tb_vld  <= 1'b0;
#20;
//// Last ////
#10;
tb_last <= 1'b1;
tb_vld_bytes <= 6'b000100;
//tb_vld_bytes <= 6'b000000;
#50;
$finish(2);
end
endmodule
Labels (3)
RichardTanSY_Altera
You have nextstate in your case statement, but state never updates to nextstate.
Fix it by adding a sequential block to update state at every clock edge.
  if (~rst)
    state <= idle;
  else
    state <= nextstate;
end
I would recommend to checkout 'Two Always Block FSM coding style' from the article below.
It uses two separate always blocks:
  1. State Register Block: A sequential (always_ff ) block that updates the current state (state_reg) on the clock edge.
  2. Next State & Output Logic Block: A combinational (always_comb) block that determines the next state and the outputs based on the current state and inputs.
http://www.sunburst-design.com/papers/CummingsSNUG2019SV_FSM1.pdf
Richard Tan
Fpga_Egr_2025
Here is the simulation results
RichardTanSY_Altera
  if (~rst)
    state <= idle;
  else
    state <= nextstate;
end
Richard Tan
Fpga_Egr_2025
HI Richard,
Yes changed the fsm to have two separate always block :
    if (~rst) begin
        state <= idle;end
else begin
        state <= nextstate;end
   end
   always @(*) begin
         nextstate <= idle;
     case(state)
idle:begin
    if(vld)begin
   rdy_sig <= 1'b1;
end
else if (last)begin
    rdy_sig      <= 1'b0;
valid_no_reg <= valid_no;
RichardTanSY_Altera
Dropping a note to ask if my last reply was helpful to you.
Do you able to resolve the issue?
Richard Tan
RichardTanSY_Altera
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you and have a great day!
Richard Tan
