Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
1238 Discussions
Which Version of Quartus supports DE10-Standard?
gkankanh
I have installed the Quartus lite edition 22.X. DE-10 standard board is not listed at all. Downloading the board support files does not work either.
JTAG consistently crashes quartus.
All help and guidance appreciated.
gkankanh
Problem Details
Error:
Internal Error: Sub-system: PGME, File: /quartus/pgm/pgme/pgme_engine.cpp, Line: 4555
count >= static_cast<DWORD>(device_chain->size())
Stack Trace:
    0x55ee1: PGME_PROGRAMMER::get_device_chain_with_dummy_jtag_bit + 0x161 (pgm_pgme)
    0x3fe8f: PGME_PROGRAMMER::engage + 0x288f (pgm_pgme)
    0x8b715: PGMWQ_PROGRAMMING_THREAD::run + 0x25 (pgm_pgmwq)
    0x2c760: QThread::start + 0x3e0 (Qt5Core)
    0x1257c: BaseThreadInitThunk + 0x1c (KERNEL32)
    0x5aa57: RtlUserThreadStart + 0x27 (ntdll)
End-trace
Quartus Prime Version 22.1std.2 Build 922 07/20/2023 SC Lite Edition
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 22.1std.2
Build: 922
Edition: Lite Edition
Elina_Intel
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Elina
Elina_Intel
Elina_Intel
May i get some update from your issue ?
Elina
gkankanh
The document you pointed to needs to be updated. The quartus version mentioned in the doc 16.1 is not available for download from the intel site. That is the reason post.
_AK6DN_
Valued Contributor II
That board was released in 2017 when QuartusII 16.1 was the current version.
Maybe you need to contact TerAsic via https://www.terasic.com.tw/en/
to see what they recommend to use at this time.
gkankanh
Thanks. I managed to get it working with quartus lite 22.1. Just want to ensure the docs get updated as long as the board is supported.
Hopefully this will help any new comers as far as required versions,  getting started and so on.
Thanks again.
Elina_Intel
Hi gkankanh,
Shall i close this case ?
Elina
Elina_Intel
Will close this case since it resolved already,
Best Regard,
Elina
