Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
hey guys homework help
i have the following program which makes a finite state machine.it compiles but doesnt simulate what could be wrong?this is the code i came up with for he question
This is an exercise in using finite state machines.
Part I
We wish to implement a finite state machine (FSM) that recognizes two specific sequences of applied input symbols,
namely four consecutive 1s or four consecutive 0s. There is an input w and an output z. Whenever w = 1 or
w = 0 for four consecutive clock pulses the value of z has to be 1; otherwise, z = 0. Overlapping sequences are
allowed, so that if w = 1 for five consecutive clock pulses the output z will be equal to 1 after the fourth and fifth
pulses. Figure 1 illustrates the required relationship between w and z.
the code
module part1a(clk, in, reset, out);
input clk, in, reset;
output [8:0] out;
reg [8:0] out;
reg [8:0] state;
reg count = 0;
parameter zero=0, one=1, two=2, three=3,four=4,five=5,six=6,seven=7,eight=8;
always @(state)
begin
case (state)
zero:
out = 9'b000000001;
one:
out = 9'b000000010;
two:
out = 9'b000000100;
three:
out = 9'b000001000;
four:
out = 9'b000010000;
five:
out = 9'b000100000;
six:
out = 9'b001000000;
seven:
out = 9'b010000000;
eight:
out = 9'b100000000;
default:
out = 9'b000000000;
endcase
end
always @(posedge clk or posedge reset)
begin
if (reset)
begin
state = zero;
count = 0;
end
else if(count==0)
begin
case (state)
zero:
if(in)
begin
state = one;
count <= 1;
end
else
begin
state = two;
count <= 1;
end
endcase
end
else if(count==1)
begin
case (state)
one:
if (in)
begin
state = three;
count <= 1;
end
else
begin
state = two;
count <= 1;
end
two:
if(!in)
begin
state = four;
count <= 2;
end
else
begin
state= one;
count = 1;
end
endcase
end
else if (count==2)
begin
case (state)
three:
if(in)
begin
state = five;
count = 3;
end
else
begin
state = two;
count = 1;
end
four:
if(!in)
begin
state = six;
count = 3;
end
else
begin
state = one;
count = 1;
end
endcase
end
else if(count==3)
begin
case (state)
five:
if(in)
begin
state = seven;
count = 4;
end
else
begin
state = two;
count=1;
end
six:
if(!in)
begin
state = eight;
count = 4;
end
else
begin
state = one;
count = 1;
end
endcase
end
else if(count==4)
begin
case(state)
seven:
if(in)
begin
state = seven;
end
else
begin
state = two;
count = 1;
end
eight:
if(!in)
begin
state = eight;
end
else
begin
state = one;
count <= 1;
end
endcase
end
else
begin
state = zero;
count <= 0;
end
end
endmodule
If I understood correctly what you want to obtain, your code is a mess.
In particular: Why that 9bit register for a single output?
You can do it with this much simpler code, involving a simple shift register.
module part1a(clk, in, reset, out); input clk, in, reset; output out; reg out; reg shifter; always @(posedge clk or posedge reset) begin if (reset) begin out <= 1'b0; shifter <= 4'b0101; end else begin if (shifter == 4'b0000) out <= 1'b0; else if (shifter == 4'b1111) out <= 1'b1; shifter <= { shifter , in }; end end
This is only sort of template; check syntax and operation.
im new to verilog and its really confusing,thanks for the help, really appreciated
